Use Points as Particles
Anti-Distinctlyminty
Let's say I have a bunch of points that I have created, and I want to treat them as particles in a popnet - how do I do this? Is it possible to do this without emitting from the source points for one frame? I noticed that you can set the initial geometry for the popobject node, and gravity and forces do effect these points, but no pop nodes do anything at all.
How do I get the pop solver to consider these points as particles?
I have attached a simple example.
(Note: The popsource node has the Geometry Source set to 'Use DOP Objects', but this is undocumented)
Points_as_Particles.hipnc
Edited by Anti-Distinctlyminty
