malexander Posted March 8, 2017 Share Posted March 8, 2017 You should download the Qt5 version unless you have some particular need for Qt4 (such as a lot of Qt4 add-on scripts, which doesn't appear to be the case). For bug fixes, you'll want the Daily Build page found here: https://www.sidefx.com/download/daily-builds Quote Link to comment Share on other sites More sharing options...
Pancho Posted March 8, 2017 Author Share Posted March 8, 2017 (edited) Thanks for the hint, but I still don't understand whether I need the regular H16 version or the one with support for Qt4. So far there's none with Qt5 support. Will there be less lag with Qt4 support? If the Qt4 version is the one to go, where do I get Qt5 from? The question I get in this link, give me the impression that I want to download a developer's toolkit. No idea at all what this is all about/correct. https://www.qt.io/download/ P.S.: Running Windows 7 on all workstations which aren't connected to the web. Edited March 8, 2017 by Pancho Quote Link to comment Share on other sites More sharing options...
lukeiamyourfather Posted March 8, 2017 Share Posted March 8, 2017 You don't need to download anything extra to install Houdini. Qt is a framework for building graphical interfaces for software that only developers need to have installed. If you don't know what this means then just download Houdini 16 installer at the top of the download page (or one of the daily builds for Houdini 16). The Qt4 version at the bottom of the page is for studios with tools built with Qt4 integrated into Houdini. Again, if you don't know what this means then just ignore the Qt4 version completely because you don't need it. Quote Link to comment Share on other sites More sharing options...
Pancho Posted March 8, 2017 Author Share Posted March 8, 2017 Cool! Thanks for the clarification. So, then waiting for new builds and hope the lags will be gone is the only way to get a usable H16? Quote Link to comment Share on other sites More sharing options...
malexander Posted March 8, 2017 Share Posted March 8, 2017 You can also try installing the Nvidia 378 driver series, if you're using an older driver. http://www.nvidia.com/Download/Find.aspx?lang=en-us 1 Quote Link to comment Share on other sites More sharing options...
lukeiamyourfather Posted March 8, 2017 Share Posted March 8, 2017 1 hour ago, Pancho said: So, then waiting for new builds and hope the lags will be gone is the only way to get a usable H16? The latest daily builds have addressed the viewport performance issues. For example the link below for the Windows daily build (16.0.541). https://www.sidefx.com/download/download-houdini/48682/ If you're not familiar with daily/nightly build concept please read this link below. They're generally not as reliable as the stable releases but they might fix bugs you're encountering and get you by until the next stable release. https://en.wikipedia.org/wiki/Daily_build Quote Link to comment Share on other sites More sharing options...
Guest tar Posted March 8, 2017 Share Posted March 8, 2017 2 hours ago, Pancho said: Cool! Thanks for the clarification. So, then waiting for new builds and hope the lags will be gone is the only way to get a usable H16? No- H16 performance will depend on the hardware you use and the software you use. Quote Link to comment Share on other sites More sharing options...
Pancho Posted March 8, 2017 Author Share Posted March 8, 2017 This seems to be H16, not hardware specific. H15.5 runs smoothly. 1 Quote Link to comment Share on other sites More sharing options...
Guest tar Posted March 8, 2017 Share Posted March 8, 2017 It runs fine here on MacOs on one monitor. Both H15.5 and H16. Quote Link to comment Share on other sites More sharing options...
lukeiamyourfather Posted March 8, 2017 Share Posted March 8, 2017 23 minutes ago, marty said: No- H16 performance will depend on the hardware you use and the software you use. There's a viewport performance issue with the first public release of Houdini 16. It has since been fixed in the daily builds (as discussed above). Below is the journal entry with at least one of the issues being fixed. https://sidefx.com/changelog/?journal=16.0&categories=&body=viewport&version=16.0.528&build_0=&build_1=&show_versions=on&show_compatibility=on&items_per_page= Quote Link to comment Share on other sites More sharing options...
Guest tar Posted March 8, 2017 Share Posted March 8, 2017 (edited) @lukeiamyourfatherI know; all the information is scattered across many posts and there are many variables - there is https://sidefx.com/forum/topic/48607/#post-219607, there is the QT4 vs 5, there is 1 vs 2 monitors. there is driver versions, there is OS versions etc. The question was is there any way to get usable H16- the answer is yes. EDIT: Anyways this whole thread only serves to reinforce positively, the validity of opening the beta up to more Indie users. EDIT2: maybe though it's all related to the latest wikileaks dump "DO NOT perform operations that will cause the target computer to be unresponsive to the user (e.g. CPU spikes, screen flashes, screen 'freezing', etc.," the document warns. https://arstechnica.com/security/2017/03/malware-101-the-cias-dos-and-donts-for-tool-developers/ Edited March 8, 2017 by tar Quote Link to comment Share on other sites More sharing options...
Thomas Helzle Posted March 8, 2017 Share Posted March 8, 2017 I can only get the Qt4 version to work at all on my Windows 8.1 x64 machine, the normal Qt5 version throws errors all the time ("No Qt binding were found") and can't find pyside. So that is another reason for the Qt4 version being there. I'm on it with support, but so far we have no clue what's wrong. Cheers, Tom Quote Link to comment Share on other sites More sharing options...
