younglegend Posted March 13, 2017 Share Posted March 13, 2017 Hey guys, i'm working on a personal project involving fireballs. I could use some help to get flame trails. Right now the flames are going straight backwards corresponding to the velocity of geo which is fast. Any tips or tricks to get those flames look interesting? I have tried negating the velocity before plugging it into fluid source. Tried emitting from particles. Both doesn't work. Thanks! Quote Link to comment Share on other sites More sharing options...
3DBandi Posted March 14, 2017 Share Posted March 14, 2017 Hi! Well, I would try to create a particle trail with some noise and use that as source for the fire. Or another way could be to put your geo to the origo, transfer the velocities from the animated (moving) geo to the still one(may be scale down a bit), and create the effect there, then give the transformations to the fire effect to snap to the moving object. Quote Link to comment Share on other sites More sharing options...
Atom Posted March 16, 2017 Share Posted March 16, 2017 Have you enabled Add Curl Noise on the Velocity Volumes tab of the FluidSource node that generates your fuel? Quote Link to comment Share on other sites More sharing options...
younglegend Posted March 17, 2017 Author Share Posted March 17, 2017 On 3/16/2017 at 2:22 PM, Atom said: Have you enabled Add Curl Noise on the Velocity Volumes tab of the FluidSource node that generates your fuel? Expand Yes, its enabled. Even tried high values. The fire behind is getting affected but not getting the desired results. Quote Link to comment Share on other sites More sharing options...
galagast Posted March 18, 2017 Share Posted March 18, 2017 What is your current sub-steps settings? It might be possible that you'll also need to increase it a bit more due to your high velocity object. Here's a quick test: H16.0.550 Indie - H16_fireball.zip Quote Link to comment Share on other sites More sharing options...
younglegend Posted March 19, 2017 Author Share Posted March 19, 2017 (edited) On 3/18/2017 at 4:29 AM, galagast said: What is your current sub-steps settings? It might be possible that you'll also need to increase it a bit more due to your high velocity object. Here's a quick test: Expand Thanks for the test file jeff. My substeps are currently at 5 actually, as the geo has high velocity like you said. My results are similar to yours. But i'm thinking of a way to make the flames, which is in front of the fireball have good trails like the ones at its back (not too much) without having to slow down the geo. Still doing some tests... Edited March 19, 2017 by kishenpj Quote Link to comment Share on other sites More sharing options...
