set parm values via python with Expressions inside
jon3de
Currently I wanted to change some rops´s image path parameters with python. I have the problem that python converts my strings with e.g. "$F4" or "$JOB" expressions in it to absolute paths. Can I avoid that?
e.g. :
c.parm("vm_picture").set("//testDirectory/teststring_$F4.v001.exr")
turns to:
//testDirectory/teststring_0079.v001.exr
How can I set this up with keeping the $JOB or $F expressions in it? is this possible?
Hmm.. this auto conversion may not be avoidable. The first thing that comes to mind, however, is that you could place your code inside the pre-render event of the ROP. Then your code will evaluate on every frame and still construct the correct filename for that frame.
Edited by Atom
What version of Houdini are you using?
It seems to be working on my end..
PYTHON SHELL:
PYTHON SHELF:
Or are you doing something differently to execute the Python code?
If not, one possible reason why it is showing as the expanded value is that you have middle clicked your parameter.
Edited by galagast
Thank you for the gifs!
I´m working with 15.5.717
Hm dont know if that makes any difference but i used this method to submit my code.
http://www.tokeru.com/cgwiki/index.php?title=HoudiniPython#Make_a_general_python_input_window
I will try it with the python shelf and with houdini 16.
Expand
No, I checked that already.
kind regards
EDIT: I checked it via python shelf and there it works! Thank you Jeff.
Would be interesting whats the problem with this self build python text editor...
Edited by jon3de
That's a cool tip from tokeru!
Seeing that that was the method used, I believe the reason why it gets expanded is because it is using the "exec()" function to evaluate the code.
You can escape it using a backslash like so:
c.parm("vm_picture").set("//testDirectory/teststring_\$F4.v001.exr")
This seemed to work :)
