HowZow Posted March 29, 2017 Share Posted March 29, 2017 Heloo, i'm new to Houdini and the goal is to get guides from the masters in here into the world of Houdini awesomeness. The concept is to get those two round spheres to swing from a higher angle and smash the text into smithereens, then, texture, light and render the project. At the moment i'm stuck at the modeling phase because i don't know how to model a procedural chain and attach it to the sphere so it becomes an asset so dynamics can be added to it. and i dont want to model it the old way, so now i need help on getting the chains done Quote Link to comment Share on other sites More sharing options...
younglegend Posted March 29, 2017 Share Posted March 29, 2017 (edited) One of many ways to do it is to draw your desired chain with curves > sweep with circle > skin. Check out the hip file. Cheers! chain_test.hipncFetching info... Edited March 29, 2017 by kishenpj Quote Link to comment Share on other sites More sharing options...
HowZow Posted March 30, 2017 Author Share Posted March 30, 2017 Thank you. i've learnt a lot from your project about the resample, sweep, skin, and merge nodes. Using this knowledge, i connected the [torus and curve] nodes to the [sweep] node. However, it's not yet sufficiently procedural. i am beginning to see how Houdini thinking is different and more advanced, there are many ways to do one thing i still need answers to move forward. How does each chain connect to each other at a varying angle of 90 degrees in a locked loop. Quote Link to comment Share on other sites More sharing options...
younglegend Posted March 30, 2017 Share Posted March 30, 2017 Here's a simpler method using copy sop. chains_2.hipnc Quote Link to comment Share on other sites More sharing options...
HowZow Posted March 31, 2017 Author Share Posted March 31, 2017 (edited) Thanks, when i opened the file, i got some errors and the file didn't load properly, so i got more tutorials about the copy sop. and tried doing it on my own, but i still don't understand it very well. How did your node end with the copy sop, because after adding copy sop i still added edit operator to manually rotate the chains by 90 degrees. Also i'm moving to the next stage which is demolition, so i will try to do this on my own and post video previz later. If i run into any problems, i will holla. And if anyone has anything else to add please tell, because Houdini is a life devotion. Plenty Thanks Edited March 31, 2017 by HowZow Added additional explanation Quote Link to comment Share on other sites More sharing options...
younglegend Posted March 31, 2017 Share Posted March 31, 2017 On 3/31/2017 at 9:42 AM, HowZow said: Thanks, when i opened the file, i got some errors and the file didn't load properly Expand Probably because you are using H15? I've attached H15 file. chains_2_H15.hipnc Quote Link to comment Share on other sites More sharing options...
HowZow Posted March 31, 2017 Author Share Posted March 31, 2017 Yes i use H15, your H15 opened with no problems. i see the power of this copy sop. i have created 2000 chains with it. Houdini is multiple awesomeness. On Tuesday April 4, I will upload simulation video of the destruction with more questions. Quote Link to comment Share on other sites More sharing options...
HowZow Posted April 4, 2017 Author Share Posted April 4, 2017 This has been a very tough phase to pass. But i keep enjoying Houdini. When i applied RBD Object to the chain and sphere, the simulation runs like a single object. so the question is how do i properly simulate the chain. Quote Link to comment Share on other sites More sharing options...
HowZow Posted April 5, 2017 Author Share Posted April 5, 2017 Why is it that the chain does not slope. Please how do i make it more accurate. am stuck at this phase thanks. chain.hipnc Quote Link to comment Share on other sites More sharing options...
Atom Posted April 5, 2017 Share Posted April 5, 2017 One solution is to make every link in the chain its own RBD object. Quote Link to comment Share on other sites More sharing options...
HowZow Posted April 5, 2017 Author Share Posted April 5, 2017 Wow, that wont be advisable in Houdini Quote Link to comment Share on other sites More sharing options...
cudarsjanis Posted April 5, 2017 Share Posted April 5, 2017 RDB packed objects should do the job. Quote Link to comment Share on other sites More sharing options...
HowZow Posted April 5, 2017 Author Share Posted April 5, 2017 I tried using RBD packed objects but the chains are interpenetrating Quote Link to comment Share on other sites More sharing options...
cudarsjanis Posted April 6, 2017 Share Posted April 6, 2017 It`s good to start with the project already, but you should learn the basics of sops, then dops, vops and then do more complex stuff. I found this to be very helpful at the beginning https://www.fxphd.com/details/?idCourse=368 But who am I to say. I started with FLIP struggled 3 months on one shot, but somehow finished it You should look in bullet data and geometry representation. and probably its convex hull by default, so change it to concave. Should do the job. Quote Link to comment Share on other sites More sharing options...
HowZow Posted April 6, 2017 Author Share Posted April 6, 2017 Yes changing it to concave did the job, somehow i missed this, wow. Thanks, but the sphere and the chain are detached and i also noticed interpolation. Initially when i started using Houdini i discovered the best way to learn is to dive into a project then figure it out as you encounter challenges, there is still a lot to learn like VEX too. So how do i attach the sphere and chain together and fix the interpolation. Quote Link to comment Share on other sites More sharing options...
cudarsjanis Posted April 7, 2017 Share Posted April 7, 2017 Yes by workjing on actual project you learn a lot, but learn basics on side, I know it might be bit boring, but that is gonna help you along the way. One more for the basics I could suggest is this guy http://helloluxx.com/product/learn-houdini-jumpstart-ultimate-bundle/ I purchased pyro and vops, Really well explained everything there. For the chain and sphere: Fastest and easiest way probably is to take one link and merge it with sphere so it`s one object. Also if sim is not working properly try increasing substebs, that should help. Quote Link to comment Share on other sites More sharing options...
HowZow Posted April 7, 2017 Author Share Posted April 7, 2017 Oh,Yes the basics. i'm swimming inside there Quote Link to comment Share on other sites More sharing options...
HowZow Posted April 7, 2017 Author Share Posted April 7, 2017 some more basics. if you're new to Houdini and your're reading this.. These are some nice basics floating around vimeo and youtube, Quote Link to comment Share on other sites More sharing options...
HowZow Posted April 7, 2017 Author Share Posted April 7, 2017 Volume 2 Quote Link to comment Share on other sites More sharing options...
HowZow Posted April 7, 2017 Author Share Posted April 7, 2017 (edited) planning to get up to volume 300 by the end of the year. downloaded volume 9 today Edited April 7, 2017 by HowZow Quote Link to comment Share on other sites More sharing options...
