(Redshift) Sprite Stencil & collision
Hi
Discovered if I use a RS Sprite Stencil operation in a custom shader to define the outline of a material I can reduce my poly count in half or more. But will collision recognize this sprite alpha outline as though it was a mesh boundary?
No, it will still appear as a grid to Houdini. You could start with a Trace followed by a UVTexture then a polyextrude. This approach should still make Redshift think it is essentially a grid but Houdini collision will find edges to collide with.
