What is the best way for ferrobrain effect?
duveil
Hi,I have been doing an R&D to achieve this effect.In the description ferro fluid is mentioned and I checked Niel Prayers`s ferro fluid tutorial but it seems different effects.Now I am looking for mixing multiple fluids with different density values .Has anyone tried sth. like this?Or can you give some advice where to look?
Atom link is a good one, the zero gravity sim has good vex to achieve your effect.
This one can also help, i think it's like entagma reaction diffusion, may be a little bit improved: from Erik Baymukashev - 2d line growth effect 01: (project provided)
2d line growth effect 02 is very close from what you are looking for, no tuts or project with that video.
I guess you'll have to mix several pieces of those projects to build that ferrobrain effect. I wish you that this thread has the same kind of success than the differential curve growth. Some info of that discussion can really help here: http://forums.odforce.net/topic/25534-differential-curve-growth/
2d_line_growth_01.hip
