Rafal123 Posted August 9, 2005 Share Posted August 9, 2005 When I hit Play, RBD simulation is on, it takes some time to calculate. When it finished and I Play again it's much more faster. Does it use cache or what? r|m Quote Link to comment Share on other sites More sharing options...
michael Posted August 9, 2005 Share Posted August 9, 2005 yep. have a quick read throught the Houdini 8 early access forum at SESI...there is some talk about it there... if you change something in your simulation you have to go back to the start frame or hit the yellow arrow thingy at the top of the viewport (you may have to open the stow bar to see it) Quote Link to comment Share on other sites More sharing options...
edward Posted August 9, 2005 Share Posted August 9, 2005 Short answer is yes. But could we all try to post all further Houdini 8 threads on the sidefx forum? Otherwise, we're not gonna be able to pool all the feedback together in one place. Quote Link to comment Share on other sites More sharing options...
bugzpodder Posted August 9, 2005 Share Posted August 9, 2005 When I hit Play, RBD simulation is on, it takes some time to calculate. When it finished and I Play again it's much more faster.Does it use cache or what? r|m 20377[/snapback] Yes. Caching is controlled by the simulations tab on the dop network node. It is turned on by default. Thanks, Jack Quote Link to comment Share on other sites More sharing options...
Rafal123 Posted August 10, 2005 Author Share Posted August 10, 2005 But could we all try to post all further Houdini 8 threads on the sidefx forum? Otherwise, we're not gonna be able to pool all the feedback together in one place. 20386[/snapback] Ok, ok. Quote Link to comment Share on other sites More sharing options...
Marc Posted August 10, 2005 Share Posted August 10, 2005 Just until the beta's over anyway, then it's all good Quote Link to comment Share on other sites More sharing options...
