How to planarize dual mesh primitive ?
scuy
Dear mestela
thank you solution. i see , use "facet / make planar " it is easy way! very helpful.
I want to keep each points connected .Is it possible to make planar like below link?
If we accept  edge and geometry shape will be changed a little bit , then we can make planar??
or there is other solution ?
Dear mestela
thank you for your advice.
I found one solution by blender.
https://blender.stackexchange.com/questions/48/what-is-the-simplest-way-to-generate-a-dodecahedron
is there anyway in houdini ?
below steps are came from above reference link.
select all the vertices in the center of each pentagon.
Dissolve Vertices to get rid of them
Limited Dissolve(bt angle)
your first picture seems to show something like a saddle surface which is partly concave. i don't think that it's geometrically possible to approximate such a surface with convex hexagonal polygons which are also planar and connected. you'll always end up with concave hexagons in your case ...
Edited by petz
