Merging and or clean up of Mesh before export as FBX
art3mis
Hi
I have a problem with an exported FBX brought into Unity after applying a translucent shader. All of the intersecting polys in the mesh become visible.(FBX_INTO_UNITY)
So I assume I need to somehow merge the polys to get rid of this. I am using a Boolean Union operation as well as a Dicide SOP(see attached .hip and network image)
Can anyone help?
walls_incorrect.hiplc
apologies if I'm totally on the wrong track....I assume you just want to cleanup the 'overlap' ?
there's probably better procedural ways...here's just a manual way....(since I'm not quite sure if I'm on the right track in the first place)
(ver 2 is more 'procedural')
walls_incorrect_cleaned.hipnc
walls_incorrect_cleaned2.hipnc
Edited by Noobini
