JJ FX Posted October 3, 2017 Share Posted October 3, 2017 Hi, I need to do some detail on a mesh, but the scene getting slow. And I was wondering, can I somehow remove inside faces, like in an example file? Removing would probably speed up my scene. remove_inside_faces_v01.hipnc Quote Link to comment Share on other sites More sharing options...
Sepu Posted October 3, 2017 Share Posted October 3, 2017 The voronoi gives you 2 prims groups, inside and outside, you can blast either or. Quote Link to comment Share on other sites More sharing options...
JJ FX Posted October 3, 2017 Author Share Posted October 3, 2017 (edited) Yeah I know that. But Im already blasting some pieces. That gives me not only inside and outside groups. Here is a screenshot. Red is inside group. And what I want to blast is the geometry thats between those pieces. Edited October 3, 2017 by JJ FX Quote Link to comment Share on other sites More sharing options...
Noobini Posted October 3, 2017 Share Posted October 3, 2017 (edited) I'm going say the bleedin' obvious.....add a Delete at the bottom, set to prims, group inside ? is that not the desired result ? (tho you said you already blasting some pieces...that was BEFORE the unpack..so not sure if this got you the result intended...prolly not) Edited October 3, 2017 by Noobini Quote Link to comment Share on other sites More sharing options...
c0y Posted October 7, 2017 Share Posted October 7, 2017 (edited) Hi, I guess what you want is deleteing the overlapping pairs of polygons. You can do that with a "clean SOP" : tick Consolidate Points, Fix overlaps, Delete Overlap Pairs and Remove Unused Points. This should delete the inside faces. remove_inside_faces_v01b.hipnc Edited October 7, 2017 by c0y 1 Quote Link to comment Share on other sites More sharing options...
