BrookerT Posted October 19, 2017 Share Posted October 19, 2017 Hello! I am having a problem with collision for my flip fluid sim, frame 2 for some reason a chunk of particles falls through the bottom of my "cup" I've checked my collisions on my "cup" and I've also tried adding a sub d node in my tree. both didn't have any result. Also, as the sim continues my particles pretty much all disappear. I'm pretty new to water sims so I'm not really sure the problem. Thanks! Quote Link to comment Share on other sites More sharing options...
Sean-R Posted October 19, 2017 Share Posted October 19, 2017 Looks like you need some thickness, use a polyextrude to create a thick barrier around the cup. Then in the dopnet, check the Collision guide under the Flip Fluid Object node to see it's true representation Quote Link to comment Share on other sites More sharing options...
BrookerT Posted October 19, 2017 Author Share Posted October 19, 2017 In a previous version I had thickness but it would still fall through the bottom, mind you it would just catch in the bottom layer but still fall through nonetheless. My secondary problem with the particles disappearing would still happen as well when I played my animation. Quote Link to comment Share on other sites More sharing options...
DaJuice Posted October 20, 2017 Share Posted October 20, 2017 Basically what Sean said. Give the cup some thickness. In your cup Static Object, make sure you have an adequate collision representation. Uncheck Display Geometry and turn on the Collision Guide, and adjust the Division Size under Collisions > RBD Solver > Volume. Once that looks good you'll want to make sure that the FLIP Object is creating adequate collision geometry from that. Turn on the Collision guide. To increase the resolution of the collision geometry created by the FLIP Object you can decrease Particle Separation, or enable Collision Separation and give it a value not tied to Particle Separation. Beyond that if you notice wonky behavior, like a few particles penetrating anyways, try increasing your substeps on the FLIP Solver. If trouble persists, please upload a file. Quote Link to comment Share on other sites More sharing options...
BrookerT Posted October 20, 2017 Author Share Posted October 20, 2017 So the advice worked! The water is staying where it's supposed to in the beginning, but then it will not leave the cup, its acting like there's and invisible polygon on the top stopping the particles from coming out. I've attached my scene file, the particles are supposed to go out and kinda "spray". splashFX_lookdev_v012.hipnc Quote Link to comment Share on other sites More sharing options...
DaJuice Posted October 21, 2017 Share Posted October 21, 2017 (edited) Change Collision Detection on your cup static object to "Use Volume Collisions". The Surface Collisions are in fact generating some polygons at the top of the cup. Edited October 21, 2017 by DaJuice Quote Link to comment Share on other sites More sharing options...
BrookerT Posted October 23, 2017 Author Share Posted October 23, 2017 After changing to volume collisions it works, one last question though. Why do I need double polygons? Is there a way to have single polygons but increase collision thickness? Thanks! Quote Link to comment Share on other sites More sharing options...
