UVs for Changing Topology Cloth
Hi guys,
I have this very specific case where i'm applying and extrude to a ripping cloth.
Everything works fine but I have no idea on how to apply UVs to this kind of geometry.
Since the mesh is animated, this is what happens when I apply an UV Layout:
Any tips would be very welcome ;)
Alvaro
Odforce.uv.hiplc
Hi Alvaro, generally you can (as with your other post regarding ID's) also just generate the UV's before the sim.
In the attached file, I also added a (hopefully not too complicated) method to generate the uv's after extruding the simulated changing-topo plane.
I colored the nodes light green and scattered notes for some of the changes I've made inside the grid_object1.
Odforce.uv.jeff.zip
  • Thanks 1
