Atom Posted November 5, 2017 Share Posted November 5, 2017 (edited) I have this simple spaceship shape. When I apply a subdivision surface it rounds out quite a bit. I don't mind some of the smoothing effect but I was hoping to keep some of the hard edges as well. I thought if I could Blendshape both versions together I might find a nice middle ground. I have setup both sides of the Blendshape so they have the same number of primitives and points. I have even sorted the primitives and points but when I move the Blendshape slider, the whole thing falls apart and looks terrible. Is there some better way to approach this kind of model mixing? AP_BLENDSHAPE_SPACESHIP_ISSUE.hiplc Edited November 6, 2017 by Atom Quote Link to comment Share on other sites More sharing options...
Noobini Posted November 5, 2017 Share Posted November 5, 2017 got partially there...dunno why some couldn't find their 'id'....hence in the Blend, they go to Origin. BLENDSHAPE_SPACESHIP_Partial.hipnc 1 Quote Link to comment Share on other sites More sharing options...
f1480187 Posted November 6, 2017 Share Posted November 6, 2017 For such kind of problems I use Match Topology node. For your case creases will work better. crease_subdiv.hipnc 1 Quote Link to comment Share on other sites More sharing options...
Atom Posted November 6, 2017 Author Share Posted November 6, 2017 (edited) Thank you both for the explanation and the examples. Edited November 6, 2017 by Atom Quote Link to comment Share on other sites More sharing options...
