How to deform animated geometry
Quite new to houdini, enjoying it very much.
I see a lot of animated mesh deformation videos on instagram recently. For instance this account has many of them.
https://www.instagram.com/_estebandiacono/
I want to learn the general logic behind these animations. I can do things like voronoi fracturing an object, or filling it with a growing spaghetti line :) but I can only do this to static geometry. I think there is a method to make those things for dynamic geo as well. Is that a trick? I hope this is a clear question.
How can I have something like this on animated structures:
If I do pointdeform before vdb, it needs to calculate vdb every frame, a bit slow and jittery, as new topology is generated every frame, however if I do the pointdeform after single time calculation of vdb then most of the geometry is stretched or deformed in an undesired way. What's the best approach in similar cases
