Delete Points based on Camera Origin
jonidunno
I'm trying to delete points bases on the camera's origin.  I have a vex script that was calculating the visibility:
vector camera_dir = point(1,"P",1) - point(1,"P",0);
f@vis = dot(@N,camera_dir);
the problem is that it's based off of having two points from a ray sop. Can I just do it based off the camera origin itself? Any help would be amazing!
Thanks,
camOrigin01_v001.hip
53 minutes ago, Noobini said:
here I've even done away with the Group...just do the N right in the Delete itself...
It looks like this method only works when you do it directly from a prim. If you scatter points or do it from the ray it doesn't work.
