Bind stamp in to VOPnoise
Hello all,
I'm modeling some tentacle creature and ran into a problem. I don't know how to stamp attribute into the VOP sop and use it to drive turbulent noise to randomise shapes for every copied tentacle. Then i want to copy that tactically geometry again and randomise tentacle shape and/or animation.
I have tried to just bind stamp("../../copy" , "id", 0) into the vop and connect it to Offset of the Noise, but for some reason, Houdini just stuck in the loop.
Please see .hip below. I feel like it is something obvious, but I cant see it. Please advice
StampinVop.hip
Edited by andrejklimov
1 hour ago, ThomasPara said:
Stamping is now obsolete, and the new method is to use "for each loop" for varying copys. http://www.sidefx.com/docs/houdini/copy/tutorial_stamping.html
Thank you for the link Thomas.
Based on the description it is exactly what I would like to do, but how do i bring "point("../foreach_begin2", 0, "id", 0)" function into VOP to control my noise?
15 hours ago, chrisdunham95 said:
If you promote whichever vop parameter your trying to copy stamp, then outside the vop, the parameter will become available and you can place your copy stamp function into it :)
Hello Chris ,
Thank you for joining the brain teaser. Could you check out my .hip file? What I would like to do is to randomize my Turbulent noise inside the pointVOP with the point attribute from the other side of the copy sop "id".
3 hours ago, andrejklimov said:
Hello Chris ,
Hey Andrej,
Take a look at what ive done, think it was what you were after :) (added a small sticky note with what I added/did also)
StampinVop_cd_fix.hip
