Deforming curve with vex (sin)
ekan de
Im trying to deform a curve with vex. I want to deform it with a sin function.
Kinda rookie on vex but i thought this would work.
I create a curve with just a start and end point.
Resample it to say 50 points.
Add a attributeWrangle and add this vex code: @P.y = sin(@P.y * 500) * 0.1;
I get no errors in the code but i dont get any result at all either.
Anyone got any clue?
I tested alot of different numbers just to make sure it wasnt the size of the sin curve but i get nothing.
assuming your line is by default in Y direction, straight up...(and why bother with resampling, in Line just say 50 points)
then it would make better sense if you perturb the X direction
@P.x = sin(@P.y * 2) * 0.1;
and 500 in houdini is huge, innit ? ahh, sorry that's freq...doesn't matter..
Still, nothing wrong with you moving in Y direction...now you're just adjusting the point distribution along Y axis that's all..
Edited by Noobini
Sorry. the curve is in x axis on the grid. i made a typo here on the forum. This is what i write in vex: @P.y = sin(@P.y * 2) * 0.1;
500 was just an example. i have tried everything from 0.1 to much much higher than 500.
Im using H16.0.5.
So it should work?
Took a glance at the link Sepu posted but need a bit more time to dig deeper and read more.
curveSine.hipnc
