Understanding matrices, quaternions and all that jazz
Hi everyone,
I would like to better understand matrices and how to use them to do what I want. I've prepared a hip file with screen shots of things I get and don't get. While writing this I'm almost making discoveries so please bare with me if it seems like a long thread :)
First off, applying a matrix3 to rotate my points seems fine as long as my vector is normalized. Else, it affects scale as well. Why is that?
1. rotate around y
matrix3 m = ident();
float angle = ch("angle") ;
vector axis = {0, 1, 0} ;
rotate(m, angle, axis);
@P *= m;
2. rotate around {0,1,1}. Not good.
vector axis = {0, 1, 1} ;
@P *= m;
3. rotate around normalize({0,1,1})
vector axis = normalize({0, 1, 1}) ;
@P *= m;
Hence, we need to normalize the rotational axis vector to prevent scaling the geometry.
Secondly, I'm having issues setting the pivot for my rotations. In the examples above this all works well if our pivot is set at the origin. So how do we set the pivot to be at the center if our geometry? Please take a look at rotate_not_at_origin object.
To begin this little science experience, I've copy stamped boxes on a single box and used the normals from the orignal box as the rotation axis vector. So far so good.
original_box.thumb.PNG.70f02eae0bd9da30a296864ca847f878.PNGcopy_stamp_origin.thumb.PNG.cf63b4d7668bc3a41c3f4064a71d4ca7.PNG
This all goes to shit if we move our original box from the origin. How do we solve this?
The only way I've seen, and don't understand, is using @orient as follows before the copy stamp. Also, this no longer copies the geometry based on the normal direction of my points.
matrix3 m = ident() ;
vector axis = normalize(v@rot_axis);
@orient = quaternion(m);
So how do we solve this? I really need to wrap my head around this once and for all gahhhhh!!
Thanks everyone!
Maxime
matrices.hipnc
There's clever ways to rotate in place (which I always forget), but just about everyone I know does the simple thing of move stuff to the origin, rotate, put back to the original position.
To make your setup work, I just added an extra wrangle before the copy to points to store the point position, as centroid:
v@centroid=@P;
Then in the rotate wrangle, subtract centroid, rotate, add centroid:
float angle = ch("angle");
@P-=v@centroid;
@P *= m;
@P+=v@centroid;
matrices_me.hipnc
-matt
A quicktip is to use the Deformation Wrangle when doing stuff like this. It will take care of your normals and stuff, rotating them too. When just using a Point Wrangle and modifying P the normals doesn't follow (or any other vectors, velocity for example).
  • Like 2
  • Thanks 1
