Export multiple OBJs
@jujoje I was about to use the geometry node in the out context and export one by one. Your method has potential... if it worked. Using a file node below your object_merge1 to write a an .bj file produces nothing. Is this working for you?
edit: Hm, something was going on, now it's working. Thanks, @jujoje, you've saved me a lot of time.
That file>export option has to see the light though.
Edited by McNistor
Glad it worked!
TBH it hadn't occurred to me to try using bundles in object merges until I read your question; was pleasantly surprised when it did what I'd hoped it would :D
1 minute ago, Atom said:
Just throw all your objects into a subnet then use a single Object merge with a wildcard to bring them all into a single object.
/obj/subnet1/*
That's a much simpler way of doing it :)
/obj/subnet1/*
believe it or not...I did do this...but wasn't cluey enough (being a non-coder) to use wildcard for merging.....sooooo close....
