Distance from center in shops
I've had things not to match in SHOPS from SOPS too, and I don't exactly know why. But one thing you can do to get your attribute in SHOPS is to store it in sops using a bind export, and then in SHOPS simply place a parameter node and read back your attribute. it should match exactly. You can later use a fit or a ramp to adjust it in SHOPS and not see the ugly poly edges in case it's not too high poly.
  On 1/9/2018 at 2:35 PM, amm said:
Well, then something else went wrong. From my small experience, it works....
Expand
Yeah, seems like it I am probably not calculating the centroid the right way. How would you do it? I really have no clue how to do it in a shader, but in a point vop I can just average the bounding box outputs...
  On 1/9/2018 at 2:37 PM, GreenGuy said:
Hey, so I did that and it did not really do anything. But it solved a couple of other problems I had, so thank you. Did not expect for shops to fall apart so quickly.
Expand
I am glad it at least solved something.. I dunno why but I find that shops throws me wonky errors now and then, so i started to use /mat context instead and it seems to work better.
any chance you can share the hip file? a bit easier to help trouble shoot with a file to look at
