Group combine pattern syntax
BludArtworks
Hello !
I’m completly lost with group syntax and wildcards. I try to combine every second primitive group. Looked at the doc (http://www.sidefx.com/docs/houdini/model/groups.html#syntax) but it doesn’t help me sadly.
Any advice ?
group_problem.hip
Edited by BludArtworks
In your copy transform output copynum attrb pack your geo then you can use the the module function in a prim wrangle to get every 2 prim grp
if(@copynum % 2 == 1){
    i@group_newGrp = 1;
You could also use the group range as well.
Edited by Sepu
