roarke80 Posted January 19, 2018 Share Posted January 19, 2018 Hi, apologies if this has been asked before but I couldn't find an answer. I've done a crowd simulation in Houdini but now need to export to alembic so I can bring it into C4D as a necessity due to my company's pipeline. I've unpacked the agent primitives and had to run through a polyreduce node to create a sensible alembic, but I've lost all the UVs along the way. I'm pretty new to Houdini, please could I have some guidance on how I can export the alembic with the original UVs please? Many thanks! Quote Link to comment Share on other sites More sharing options...
Atom Posted January 19, 2018 Share Posted January 19, 2018 (edited) Polyreduce should preserve your UVs. Inspect that the UVs are present before you process them with the polyreduce. Also, Cinema4D may require some special TAG be applied after input to recover attributes such as color or UVs. Are the UVs present if you re-import the Alembic into Houdini? You may need to follow up your Alembic node with an Unpack to see the stored attributes. Edited January 19, 2018 by Atom Quote Link to comment Share on other sites More sharing options...
roarke80 Posted January 22, 2018 Author Share Posted January 22, 2018 Thanks very much for your response! My problem is the UVs are distorted right after I unpack them, so even before I hit poly reduce. Is there a way to preserve the same UVs during unpacking? thanks! Quote Link to comment Share on other sites More sharing options...
Atom Posted January 22, 2018 Share Posted January 22, 2018 (edited) If your UVs are wrong when you unpack them then you need to fix them in the app or network that generates the packed objects. Can you post one of these problem agents? Edited January 22, 2018 by Atom Quote Link to comment Share on other sites More sharing options...
