Define a function in point wrangle
13 minutes ago, AntoineSfx said:
So this was an error (; instead of ,) but I still can't get this to compile, because of the array type as return type:
int [] myfunc(int input; int ptnum)
{ int  result[];
   return result;
not sure that vex allows return array
On 27/01/2018 at 8:39 AM, julian johnson said:
function int[] test()
        int result[] = {1,2,3};
        return result;
i[]@test = test();
I get syntax errors using the 'normal' array syntax in the documentation i.e. a simple int[] test(){}; but if you disambiguate using the 'function' syntax it seems to work..
This solves my problem. May I ask where you have found this ? Is there a BNF for VEX ?
Edited by AntoineSfx
3 hours ago, julian johnson said:
I found this in the documentation:
http://www.sidefx.com/docs/houdini/vex/arrays.html
Not sure what a BNR is :-)
ok. Typo.. I meant BNF, the formal definition of the language (Backus normal form)
Also, the use case of the keyword function is for nested functions.
So I assume the whole VEX block is really run inside a parallel for loop over prim / points ..
// VEX Code Generated by Houdini 16.5.268
// Date: Sun Jan 28 16:23:25 2018
// File: C:/Users/johnson/untitled
// Node: /obj/geo1/attribwrangle2/attribvop1
#ifndef VOP_OP
#define VOP_OP
#endif
#ifndef VOP_CVEX
#define VOP_CVEX
#endif
#pragma opname attribvop1
#pragma oplabel "Local Vop Code"
#pragma opmininputs 1
#pragma opmaxinputs 1
#include <math.h>
void
_obj_geo1_attribwrangle2_attribvop1_snippet1(int _bound_test[])
            return result;
    _bound_test = test();
cvex
obj_geo1_attribwrangle2_attribvop1(export int test[] = {})
    // Code produced by: snippet1
    _obj_geo1_attribwrangle2_attribvop1_snippet1(test);
Looks like a nested function when you expand the inner VOP node to VEX...
