Hey Everyone!
So the issue is... I am using Voronoi to fracture an object. The inside and outside faces are in two groups named 'inside' and 'outside'.
I'm using the 'assemble' node to pack the primitives however, doing this, it looses the 'inside' and 'outside' groups which I need to use later on.
Is there a way to use the assemble node and keep the groups?
Any advice is massively appreciated!
Thanks All!
Edited by MilesS1
6 minutes ago, lugnut said:
Turn on "Transfer Groups" in the assemble SOP. Check if there are any attribs you want to transfer if so tick that on too
Hey John,
Thanks of replying. I am placing the 'inside' & 'outside' groups in the 'Transfer Groups' field in the assemble sop. It transfers the 'inside' and 'outside' groups but testing with the delete node, the groups transfer over but the geometry within each group changes?
Basically the geometry in the 'inside' group is different once it has been through the assemble node. (Same applies for the 'outside' group)
Is it something I'm doing wrong in the assemble node?
Thanks again for replying!
