EuniceC Posted February 6, 2018 Share Posted February 6, 2018 Hi, I am trying to create some kind of saliva effect from a creature's roar when it opens its mouth, something like this. I researched for quite a bit and understood that this can be done with the wire solver. However, I'm getting stuck at getting the constraints to work!! I created a line and made it wire object. Then, I use glue-wire-to-animation from the shelf tab to constrain the line to my model. I want to constrain the 2 end points of the line to the animated object. I can see the constrain but it is not moving with the animation. I'm not sure what I did wrong and how to fix this. I don't really understand constraint network since it's my first time working with it. Can someone please help? How do I constrain my wire object to an animated object? I also thought of scattering points of my model and use the add node to first create the saliva. But what I don't understand is then how do I define so that the points on attach from top to bottom rather than left to right. Any advice on this? Here is a reference video. What I would like to achieve is something very similar to this at 0.09s. https://www.markinglevfx.com/projects/6477328. Here's another one but the description was too brief that I still don't understand how does it go from wire to pop for dynamic and meshing. Thanks, Eunice Quote Link to comment Share on other sites More sharing options...
Atom Posted February 7, 2018 Share Posted February 7, 2018 Maybe check out the Snot thread. Quote Link to comment Share on other sites More sharing options...
wacool Posted February 8, 2018 Share Posted February 8, 2018 some with wire t.hipnc 1 Quote Link to comment Share on other sites More sharing options...
EuniceC Posted February 10, 2018 Author Share Posted February 10, 2018 On 2/7/2018 at 9:48 PM, Atom said: Maybe check out the Snot thread. On 2/8/2018 at 10:38 PM, wacool said: some with wire t.hipnc Thanks Atom and wacool for the guidance! and many thanks to wacool for giving an example files on how to customise something like that. I ended using a mixture of cloth, FEM and wire to achieve what I want. It's a good start for myself. Quote Link to comment Share on other sites More sharing options...
