Bulgrozz Posted February 19, 2018 Share Posted February 19, 2018 Hi! I'm not sure wether it is a real issue or not. I just don't understand why, under certain circumstances, the polyExtrude don't weld the extruded points (though Divide Into is set to Connected Components). This short video will show what I mean: Quote Link to comment Share on other sites More sharing options...
nuki Posted February 22, 2018 Share Posted February 22, 2018 Weird. If instead of using the extrudeFrontSeam group you create another unshared edge group between the two polyextrudes you end up with 24 points. Both groups are identical though. Quote Link to comment Share on other sites More sharing options...
Bulgrozz Posted March 5, 2018 Author Share Posted March 5, 2018 You're right. The extrudeFrontSeam group seems broken... Quote Link to comment Share on other sites More sharing options...
Daniel_Daniel Posted February 4, 2019 Share Posted February 4, 2019 Has anyone found a solution for this? Quote Link to comment Share on other sites More sharing options...
Noobini Posted February 4, 2019 Share Posted February 4, 2019 some sort of bug. If you try rename group extrudeFrontSeam to SomeNewName, then extrude group SomeNewName it still doesn't work. However if you use a group SOP to show extrudeFrontSeam, then enter new name in Group Name as SomeNewName, then extrude that...it will work. The extrudeFrontSeam/extrudeBackSeam that come out of the extrude SOP is buggy. Quote Link to comment Share on other sites More sharing options...
