Perpenticular World Space Tangent on Surface
Entropy
that is ridiculously simple thanks a lot @petz
any idea why the boolean operation reverses randomly the curve direction
even when the same object copy is used to intersect ?
i use various meshes not just planes to cut - intersect surfaces with the boolean operation
and create the surface tangents perpendicular to the curves
but there are inconsistency with the extracted curves
is there any easy way to find those problematic curves and reverse them ?
thanks in advance
Edited by Entropy
due to the use of "remove shared edges" in the divideSop you got always two coincident polygons for every section. you need to delete duplicates and then make sure the normals of remaining prims are pointing into the same direction.
instead, you could also set the output of the booleanSop to "seam" and check the curve direction based on point neighbours ...
hth.
petz
i had no success determining whether or not a curve has its points ordered clockwise or anticlockwise
float sum = 0.0;
for (int i = 0; i < i@numpt; i++) {
   vector v1 = point(0,"P",i);
   vector v2 = point(0,"P",i+1) % i@numpt;
   sum += (v2.x - v1.x) * (v2.y + v1.y);// * (v2.z - v1.z);
setprimgroup (0, "reverse", @primnum, 0, "set");
if(sum > 0){
  setprimgroup (0, "reverse", @primnum, 1, "set");
obviously it is not right the above solution is for a 2d curve
any idea for the 3d equivalent  ?
Edited by Entropy
Hi satoru thanks for your reply
but unfortunately this is not working for my case
i uploaded a new file to illustrate the issue
i use polycut the result is the same as with boolean operations
the unshared  edges always produse two coincident polygons as petz said
perpenticular_tangent_polycut.hipnc
Edited by Entropy
  • 3 years later...
On 02/03/2018 at 2:17 PM, satoru said:
If it is a curve extracted from the surface, you can determine the direction with the inner product of the original N and the new N.
I am sorry if it is a misunderstanding.
perpenticular_tangent_polycut_sy.hipnc
Trying to have all complex curves network i have to deal with  be oriented properly to be able to use a signed distance to cut my mesh precisely without having to increase the mesh density, for this is need to orient my curves properllu.
To what i could see in your simple example, while the orientation of the close curves are not correct, the tangent vector are oriently not uniformly in the same consistent direction, like for the mouth . I try to sort but didn't solve , any idea?
@petz
@vinyvince
Math- 2016/-Sarajevo /Jaroslav Cerni/Berlin/Math/
How you cut your Geo?
Can you Share some simple ex on Your exampel
If its not for Rocket Science project that you do :P
int he = pointhedge(0,@ptnum);
vector nextP = attrib(0,'point','P',hedge_dstpoint(0,he));
vector edgeVector = nextP-@P;
if (he==-1){edgeVector={0,0,0};} // in case this is an end point
f@pscale = length(edgeVector);
v@tangent = normalize(edgeVector);
p@orient;
#include "math.h"
int n = npoints(0);
// first point orientation
vector xaxis = {1,0,0};
vector tangent = attrib(0,"point","tangent",0);
vector rotaxis = normalize(cross(xaxis,tangent));
float rotangle = acos(dot(xaxis,tangent));
vector4 Q = quaternion(rotangle,rotaxis);
setpointattrib(geoself(),"orient",0,Q);
// parallel transport
int currPoint = 0;
vector4 cumQ=Q;
do{
  int he = pointhedge(0,currPoint);
  int nextPoint = hedge_dstpoint(0,he);
  if (nextPoint==-1){break;}// in case this is the end point
  vector currTan = attrib(0,"point","tangent",currPoint);
  vector nextTan = attrib(0,"point","tangent",nextPoint);
  rotaxis = normalize(cross(currTan,nextTan));
  rotangle = acos(dot(currTan,nextTan));
  cumQ = qmultiply(Q,cumQ);
  // optional: additional twist by PI/2 for interlocking rings
  vector4 R = quaternion(PI/1,nextTan);
  cumQ = qmultiply(R,cumQ);
  setpointattrib(geoself(),"orient",nextPoint,cumQ);
  currPoint = nextPoint;
}while(currPoint!=0);
Oh my task for this studio is completed Tesan, i refused a couple of jobs, las t one yesterday as i need to rest a bit or i didn't feel exited :)
The example im using is the one used in this forum , just noticing the tangent orientation could go CW or CCW for the curves where the winding have been solved, after on some complex case, i have a bunch of 3d curves in space which will like to orient all in the same direction. in 2d space , you could use a circle or cyl mapping to order then and polyframe, but in 3d space, i haven't found out. Just looking at the I don't have the math.library,  What's
this line is supposed to do?
p@orient;
This is an example of what i haven't fun with personally... Looks like mostly everyone is only considering Houdini for FX or scene assembly, a pity no?
sorry for the Opengl capture, no power or time to make a beautiful render here :)
No uv , only input is this glorious female mesh
________________________________________________________________
Vincent Thomas   (VFX and Art since 1998)
Senior Env and Lighting  artist & Houdini generalist & Creative Concepts
 http://fr.linkedin.com/in/vincentthomas
Edited by vinyvince
