vinyvince Posted February 27, 2018 Share Posted February 27, 2018 Upgrade Houdini file from non commercial file to commercial version... I guess very clear what it is supposed to do isn it? Yes, its a really a pity, why isn it notpossible or you have to use so much tricks? And what about people who start using a non commercial version and whoare switching after? Such time lost indeed... Looking forward your suggestion and opinion, cheers bout.de.lune@gmail.com Quote Link to comment Share on other sites More sharing options...
Sepu Posted February 27, 2018 Share Posted February 27, 2018 send the files to sidefx they will do the conversion for you. 1 Quote Link to comment Share on other sites More sharing options...
vinyvince Posted February 27, 2018 Author Share Posted February 27, 2018 Thanks for your answer. Not the smoother and most handy solution i could imagine, a pain if there are no other way Quote Link to comment Share on other sites More sharing options...
ikoon Posted February 28, 2018 Share Posted February 28, 2018 (edited) I was Apprentice, then Indie. I think, that I was able to copypaste from my .HIPNC into my .HIPLC ... (maybe there was some signature in those .hipnc, that indicated I created them on the same machine/id?) I cannot describe it more accurately, those are just old occasional situations that I had. Edited November 6, 2019 by ikoon Quote Link to comment Share on other sites More sharing options...
vinyvince Posted March 1, 2018 Author Share Posted March 1, 2018 I thought there was some python or Hscript who could do this.. Quote Link to comment Share on other sites More sharing options...
lukeiamyourfather Posted March 1, 2018 Share Posted March 1, 2018 You're completely missing the point. It's a licensing restriction. SESI doesn't want people using the Apprentice version or Indie version to do major commercial work. That's what the more expensive commercial versions are for. If it was easy to convert the file types then it would be easy to break the license agreements. It's supposed to be a pain in the ass and controlled by only a few so the licensing agreements can actually be enforced. It's the same situation with the Orbolt assets too. If you buy the Indie version of the Orbolt asset it won't work in the commercial versions of Houdini. I think SESI will do a one time conversion of files (but probably not Orbolt assets) if a commercial version of Houdini was recently purchased. Other than that one time situation the different scene formats don't intermingle or convert. 1 Quote Link to comment Share on other sites More sharing options...
vinyvince Posted March 1, 2018 Author Share Posted March 1, 2018 I see , no worry, thanks Quote Link to comment Share on other sites More sharing options...
ikoon Posted March 8, 2018 Share Posted March 8, 2018 (edited) Here is the Houdini Apprentice HD to Houdini Indie Converter https://www.orbolt.com/upgrade-houdini-files It may help you. I did not test it as I don't want to waste one of limited times. So excuse me if it did not work for you. EDIT: I needed it later and it worked fine. Edited July 29, 2019 by ikoon update 1 1 Quote Link to comment Share on other sites More sharing options...
wisedoggs Posted May 14, 2019 Share Posted May 14, 2019 Someone on here helped me figure something out, but now I can't use my commercial project but add in their little helper file, it will make the project non-commercial. I get the licensing aspect, but this sucks for those who paid for license. Quote Link to comment Share on other sites More sharing options...
craboom Posted November 6, 2019 Share Posted November 6, 2019 I have some similar problem. I am working on a project sind a few weeks in houdini indie. Yesterday i was opening another file from the apprentice version to look into that for some hints that can help me with my actual project. Houdini said that it now enters a non-commercial-session-mode, wich was fine, cause it was an apprentice project that i opened. Then i reopened my actual project and worked there, i didn´t copy anything from other project in there, i have typed all in by hand and created all the nodes by my self. Today i wanted to open my project and i get the popup that says that houdini will open this project in non-commercial-session-mode, what the hell? Just by opening another non-commercial-project all my other proejcts are now non-commercial too? What´s that? How can i fix it? Makes me mad about it Quote Link to comment Share on other sites More sharing options...
kiko Posted July 12, 2020 Share Posted July 12, 2020 (edited) Try using opscript command trick https://kiko3d.wordpress.com/2015/03/19/converting-houdini-not-commercial-files/ Edited July 13, 2020 by kiko 2 3 Quote Link to comment Share on other sites More sharing options...
Kareeem Posted 12 hours ago Share Posted 12 hours ago On 7/13/2020 at 12:46 AM, kiko said: Try using opscript command trick https://kiko3d.wordpress.com/2015/03/19/converting-houdini-not-commercial-files/ this still works! Quote Link to comment Share on other sites More sharing options...
