kishan Posted February 28, 2018 Share Posted February 28, 2018 (edited) anyone pls fix my orientation problem...the cubes is not rotated...pls give fixed file sir....i need same method of fixed file.. [sorry for bad english] sample2.hipnc Edited February 28, 2018 by kishan Quote Link to comment Share on other sites More sharing options...
kishan Posted February 28, 2018 Author Share Posted February 28, 2018 pls help anyone Quote Link to comment Share on other sites More sharing options...
kishan Posted February 28, 2018 Author Share Posted February 28, 2018 1 hour ago, kishan said: pls help anyone pls help anyone Quote Link to comment Share on other sites More sharing options...
kishan Posted March 1, 2018 Author Share Posted March 1, 2018 sir iam begeiner ...iam tring to go next level.pls help me.. Quote Link to comment Share on other sites More sharing options...
satoru Posted March 1, 2018 Share Posted March 1, 2018 Like this? rot_constraint.hipnc 3 Quote Link to comment Share on other sites More sharing options...
kishan Posted March 2, 2018 Author Share Posted March 2, 2018 yes,its works perfectly...very very thanks sir.................. thank you very much,problem solved... Quote Link to comment Share on other sites More sharing options...
kishan Posted March 6, 2018 Author Share Posted March 6, 2018 (edited) Dear sir, one more problem in condof/condir.. in this scene,orient is given for first wheel only..so it rotates. but how to rotate second wheel automaticialy ?(through condof/condir) (sorry for my bad english/kindly help me/pls give fixed file) constraint problem10.hip Edited March 6, 2018 by kishan Quote Link to comment Share on other sites More sharing options...
kishan Posted March 6, 2018 Author Share Posted March 6, 2018 anyone help me pls Quote Link to comment Share on other sites More sharing options...
Atom Posted March 6, 2018 Share Posted March 6, 2018 (edited) Wouldn't you just need something like this on the group field of the attribute vop? //OLD @name="piece1" //New @name!="piece0" If it is not equal to piece0 then piece1 and piece2 will be processed. Edited March 6, 2018 by Atom Quote Link to comment Share on other sites More sharing options...
kishan Posted March 6, 2018 Author Share Posted March 6, 2018 (edited) sir,i know that method.any other method..?(through condof/condir) pls reply me sir.. Edited March 6, 2018 by kishan Quote Link to comment Share on other sites More sharing options...
vicvvsh Posted March 8, 2018 Share Posted March 8, 2018 Hi. Maybe it what are you looking for? constraint problem10_1.hipnc 1 Quote Link to comment Share on other sites More sharing options...
kishan Posted March 8, 2018 Author Share Posted March 8, 2018 (edited) yes,,,absolutely right...thank you very much sir.. my final dought pls.the second wheel is rotated freely.i want limited rotation.ex:-30 deg to +30 deg.how to get it ? pls solve my fianl dought sir.... (how to control these type of constraint rotation) constraint problem10_2.hipnc Edited March 8, 2018 by kishan Quote Link to comment Share on other sites More sharing options...
vicvvsh Posted March 9, 2018 Share Posted March 9, 2018 How about this variant but with limited rotation only 0 deg constraint problem10_3.hipnc Quote Link to comment Share on other sites More sharing options...
vicvvsh Posted March 9, 2018 Share Posted March 9, 2018 This example file with limit rotation as you asked. You can adjust limit in an attribute wrangle node "angle_limit" with parameter "angle_limit" constraint problem10_4.hipnc 1 Quote Link to comment Share on other sites More sharing options...
kishan Posted March 10, 2018 Author Share Posted March 10, 2018 thank you very much...my all doughts solved..... thank you...thank you...........thank you.... Quote Link to comment Share on other sites More sharing options...
