Double Sided Primitive ?
If you need to create a two sided material maybe this thread will help you.
https://www.sidefx.com/forum/topic/30348/
28 minutes ago, CinnamonMetal said:
Is it possible to have two sets of normals parallel to each other with control over each separate normal
As the normals are just vectors you can have of course a lot of custom "normal" attributes on your geometry. Depends on what you are after you can create N1, N2, N3...... Attributes.
Edited by jon3de
  • Thanks 1
