Problems with Polyfill/Polybridge
PlatinumFishy
So I am attempting to make a properly subdivide-able inset for this irregular curved geometry. I used UV's in order to place the shape of the inset on the base geometry. The problem I am facing is that I am unable to easily connect the inset with the border of the base geometry. Poly bridge and Poly fill have both failed me (or maybe I am not using them right) so if anyone has any suggestions on how to fix the problem that would be great.
P.S. I was wanting to preserve the original shape but even if I were to get the polyfill/polybridge to work properly I doubt it would still have the same shape as the original. I was going to try to use UV's again to refit the geometry but I am not entirely sure if it would work, so if anyone has advice on returning it to its initial geometry that would be great.
inset.hiplc
I try to use polyextrude instead...hard to say in general what the alternate to bridge would be...but I would probably rethink my design...sounds drastic yes..but here's an example:
I started with bridge....lost some hair...then decided to abandon bridge and started all over again with a different design (ver 1.04 on)....just works...
