Condition for choosing between Polyextrude or Polyfill
vrman
i have a model with 2000 pieces , some of them need to use polyfill and some of them need to use polyextrude.
the problem is i cant find a way to make a condition to seperating them.
the correct result should be like this (pic_1) :
when they only use polyextude (pic_2) :
and when the only use polyfill (pic_3) :
i want to make a condition for change switch node to use correct sop for each object.
is there any solution to fix this situation ?
thanks alot
Condition_problem.hipnc
Edited by vrman
  • 2 weeks later...
  On 4/15/2018 at 2:30 PM, f1480187 said:
 while piece missing a quad will have only 4.
Condition_problem_fix.hipncFetching info...
what if the pieces are more complexed...ie. the hole is not a nice quad ?
Here's my workaround, I've added a subdiv to the box to force non-quad hole. Then use the 'default' Bool operation to detect self-intersection which is the problem when you cap/fill a somewhat planar/sheet object.
Condition_problem_vu_mod.hipnc
