Random with percentage probabilities for different results
Christoph_H
I have problems for the following configuration:
I tried to use an If Loop in the wrangler to add certain percentage probabilities.
I failed, however.
In this case:
a 20 percent probability that he does not select a point.
a 35 percent probability that he selects 2 points.
a 45% probability that he selects 4 points.
The whole thing would have to be subject to a random function with seed.
So far I have the impression that I would have to combine several random functions.
I have no idea how to do this. I also searched the Internet, but found nothing that would have helped me.
Thanks again for your help.
I took the first brute force idea from this topic and implement it with VEX. Connect Attribute wrangle node to a geometry and check @show attribute in Geometry Spreadsheet:
float rand = rint(rand(@ptnum)*10);
int porbMap[] = {0,0,2,2,2,4,4,4,4,4};
int randMapped = porbMap[rand];
s@show = sprintf('%s', randMapped);
the probMap is an array where you define your conditions. I reduce array size from 100 to 10, so instead of  20 zeros for 20% probability of selecting zero points, you need to enter only 2 (30% probability to select 2 points and 50% probability to select 4 points).
Its awful algorithm and I am not 100% sure If it's working correctly. Certainly, there should be a more elegant solution!
Edited by kiryha
35 minutes ago, kiryha said:
Hi, Jesper! Nice setup!
How does this command work?
rand(@ptnum +45,65)
I did not find three arguments example in docs.
Cheers!
actually it is just the regular rand() function with one argument. I just added to that one value argument. so rand(@ptnum + 45.65 + @seed), all turn into one value. (I realize in my previous post I used komma , instead of dot to declare the decimal. its an old European habbit and is wrong. the number should be 45.65)
