Clouds, I3d Artifacts
Rafal123
Hi people!
I little played today with i3D clouds but I get strange artifacts on the clouds.
First things are 'stairs' on the clouds edge. I emitt these from poly geos, so I thought it becouse of geo. Then I deleted geo but still get this stuff.
Also clouds have many dots, they r very grainy. Does it becouse of shader?
Check it out: http://www.rafal.stnet.pl/rafal_cloud_test1.jpg
r|m
23948[/snapback]
for this problem you might try truning down/off the compression in your 3d texture ROP.
This usually clears up this problem.
All the best
Luca
23948[/snapback]
I'm guessing that you're using adaptive step in you fog shader, I would turn this off.
Is seem to remember adaptive step giving me nothing but problems.
Luca
Luca
23968[/snapback]
Yeah, it will be slower to render in some scenarios but you will get uniform quality at least.
  • 2 weeks later...
how long does it take this render/i3d generation on your machine?
Making a nice clouds is not a problem, making them fast... this is a chalange!
24513[/snapback]
I'm not sure.... few minutes I think...
are there any option to show render times in Mplay??
and my machine is old and slooow --> Celeron 1.7ghz + old Nvidia
  • 2 weeks later...
nice ... i was also testing some clouds last week... well.. i should say smokes... cause i was trying to get a face.. smoked and dusted ... lemme exaplain with my engrish :)
a face.. which falls down like it becomes powder .. dust.. or like the mummy to make an example.. and i wanted also to fill all this with a sort of smoke.. and i tried I3d..
I'd like to see some cool examples on this topic actually.. maybe Jason can show up something to "trick" or improve quality and render times?
25054[/snapback]
cool clouds,
is there any way to get nice dense clouds with hard shadows? like volcanic smoke?
it seems you can't with the deflaut shaders.
