Rotate cameras from vector list to degrees
konstantin magnus
I have read lots of camera angles from a text file, and try to convert them from vectors to degrees:
rot_list = rots.split()
# ['0.768704', '-0.628123', '-0.120648']
rot_deg = hou.Vector3.angleTo(rot_list)
node_camera.parmTuple('r').set(rot_deg)
It throws an error: unbound method angleTo() must be called with Vector3 instance as first argument (got str instance instead)
Edited by konstantin magnus
it's not really clear what [ '0.768704',  '-0.628123', '-0.120648' ] is. Is it the xyz values of the camera's rotation or is it the vector the camera points to? (like houdini cam points to (0, 0, -1) by default)
I'm asking because angleTo() returns the degrees between 2 vectors as a float value.
So your code would fail because you dont specify the first of those 2 vectors. the line should be something like rot_deg = hou.Vector3(0,0,0).angleTo(rot_list)
next issue - your error message: the list returns the values as strings (notice the ' ' ). so you might add a step and fix that like so: myVec = hou.Vector3(float(rot_list[0]), float(rot_list[1]), float(rot_list[2]))
and then use rot_deg = ... angleTo(myVec) with proper vector3 as argument
still, you then try to set a single float to the parmTuple('r') wich is not gonna work as it expects a sequence of values
In case of it being radians you could
import math
and with math.degrees(float(rot_list[0])) convert it to degrees
save that in a list and try feeding that into parmTuple.set()
Edited by 3dome
Hi Dominik, thanks for your help.
Expand
Its a vector deviating from {0,0,-1}, exactly like the line SOP. So I am still looking for a method to convert this 3d vector to 3 degree values rx, ry, rz.
How is this usually done in Python?
Hi Konstantin!
If i understood you right it must be working. 0,0,-1 is initial direction for a camera, rotDeg is vector with rotation in degrees.
def vtd(vector):
    vec = hou.Vector3(vector).normalized()
    m4 = hou.Vector3(0,0,-1).matrixToRotateTo(vec)
    m3 = m4.extractRotationMatrix3()
    rotDeg = m3.extractRotates()
    return rotDeg
  • 2 weeks later...
Try this:
def vtd(vector):
    initDir = hou.Vector3(0,0,-1)
    initUp = hou.Vector3(0,1,0)
    m4 = initDir.matrixToRotateTo(vec)
    dir = initDir * m4
    up = initUp * m4
    newUp = dir.cross(initUp.cross(dir))
    mrx = m4 * up.matrixToRotateTo(newUp)
    m3 = mrx.extractRotationMatrix3()
    return rotDeg
