Buckingham Palace in Westeros context
vhalldez
Finishing an old project that I had stopped.
The idea is to do the Buckingham Palace at Westeros context, the carpet is westeros map, the wallpapper have dragons, and Kings on the frames at right.
Thank you Amok Amokov by let me use yours ilustrations of Targaryen Kings.
I am posting some Houdini projects on my Instagram
/www.instagram.com/valdez_oa/
noiiiiiice...
- carpet looks paper thin tho
- the red chairs...they look so short you'd think they're made exclusively for Tyrion
- the curtain's opacity's bit weird...upper left you could see right thru to the outside wall
- floating candalabra in the mirror...the faux fireplace must reflected as well ?
Edited by Noobini
thank Noobini by the answer
-I thought to use displacement of fur on the carpet but, the scene is already so heavy that i give up.
-Do you thought the red chair shot? hmmm..forhaps..seeing now, forhaps :)
-You is right about the curtain and fireplace, I made that choice by aesthetics only..the reflection of fireplace was so bright above the chair, and it got weid..so I removed.reading you now forhaps I could make a little reflect on pos..
I will make that impluvments..thanks again
