Read files through a loop
I have a large number of wedges, but I used the wedge to simulate different section of one large simulation. Now I need to read them all in and merge them into a single geo. I have 82 wedges, is there a way to bring them in without having to use 82 filecache nodes? I tried to run a loop and collect all the files, I used the iteration detail attribute in place of the wedge to cont the numebr of times the filecache should loop, it doesn't work. i might be missing something, please enlighten me.
hey Suraj use a file merge, and put $SLICE where the wedge variable in your filename is and adjust the merge range.
e.x $HIP.whatever.wedgevar_1.bgeo =  $HIP.whatever.wedgevar_$SLICE.bgeo
  • Thanks 1
