iFight4theUser Posted June 28, 2018 Share Posted June 28, 2018 (edited) Hello hive mind! I'm looking for a better solution to saving out my flipbooks as .mp4s. Right now I have ffmpeg installed so I can go directly from mplay and save an .mp4, but I cannot figure out how to change the preset for the menu so that the default file name matches my naming convention. Which is really annoying. I'm looking for any of these solutions! 1) Does anyone know how to update this ffmpeg window with a custom string in the "Output File" field? 2) Does anyone know where mplay stores the tmp images, so I could grab them straight from there and go to ffmpeg from a shell? 3) Does anyone have a better solution for flipbooking? Thanks! Edited June 28, 2018 by iFight4theUser Quote Link to comment Share on other sites More sharing options...
pxptpw Posted August 5, 2018 Share Posted August 5, 2018 Hello Ryan, saw this topic regarding flipbooks, and as i was pondering over this a while ago as well ,tinkered with some stuff and came up with this , sets the hip name from hip file path sets the screen resolution tp 1920x1080 sets the zoom factor to 100 percent sets the frame range from start end frame range this is in Windows so use the backslah forward slash appropriately when in linux drag and drop on the shelf and change the mode to python or create your own custom hda with input values import hou import os cur_desktop = hou.ui.curDesktop() scene = cur_desktop.paneTabOfType(hou.paneTabType.SceneViewer) flipbook_options = scene.flipbookSettings().stash() playbar_options = hou.playbar hip_file = hou.hipFile path_name = hip_file.name() file_name = hip_file.basename() spli_file_name = file_name.split(".") spli_path_name = path_name.split(".") frame_range = playbar_options.frameRange() flipbook_options.frameRange( (int(frame_range[0]),int(frame_range[1])) ) new_dir_path = str(spli_path_name[0]) if not os.path.exists(new_dir_path): os.makedirs(new_dir_path) flipbook_options.output(spli_path_name[0]+"/"+spli_file_name[0]+".$F4.exr") flipbook_options.outputZoom(100) flipbook_options.useResolution(1) flipbook_options.resolution((1920,1080)) flipbook_options.cropOutMaskOverlay(1) scene.flipbook(scene.curViewport(), flipbook_options) 1 Quote Link to comment Share on other sites More sharing options...
iFight4theUser Posted August 6, 2018 Author Share Posted August 6, 2018 Hey Hey! Cool thx JN! I'll check this out and see if I like this solution. I think my plan right now is to have the flipbooks write to a tmp location, and then generate a dropdown menu to select from the tmp versions which I want to run through a os.cmd( fffmpeg ... ) type of command. Thanks! Quote Link to comment Share on other sites More sharing options...
