jon3de Posted July 10, 2018 Share Posted July 10, 2018 (edited) Hi, I have a strange behavior with the auto Rig Tool in Houdini 16.5 If want to create a Asset it just creates 3 helpers and a merge node and I´m not able to add a Head / Arm etc. In Houdini 16.0 it works fine....Anyone else noticed this behavior? I attached a screen capture to demonstrate. AutoRig_Bug.flv Edited July 10, 2018 by jon3de Quote Link to comment Share on other sites More sharing options...
Atom Posted July 10, 2018 Share Posted July 10, 2018 That is odd, I just tried the same thing using H16.5.496 and it worked. My guess is there may be some pathing/ENV path issues with your python setup or your houdini.env. Try the old trick of deleting (or move to your desktop) your houdini.16.5 from Username/Documents. Then restart Houdini and it will re-create the missing folder with defaults. This can sometimes fix configuration errors. Have you done any custom configuration on your python environment variables? 1 Quote Link to comment Share on other sites More sharing options...
jon3de Posted July 10, 2018 Author Share Posted July 10, 2018 Although I cant remember of any custom configuration stuff I should have done, this solved the error. Thank you! Quote Link to comment Share on other sites More sharing options...
