clustering and merging fuel
logix1390
Hello,
I have a fire simulation with a constant fuel value of 1. Now, i want to randomize the flame height on the same emitter so that there is a clear distinction that there are bigger fires and smaller ones.
My solution is to add in additional fuel that is remapped by a cluster attribute.
 I would like to know if there is a better way of doing this or if this is the way to go. I don't seem to be getting very noticeable results either.
I am also not sure if I am merging in my fuel properly... I am using a volume mix in this case
Any tips would be greatly appreciated.
I will attach my scene file for anyone that wants to take a look.
Thank you.
clustering fuel.hip
Hi fencer ,
Thank you for the file. This works well in terms of merging the fuel. I was wondering if there was a way to properly randomize chunks of fuel with different values in a more procedural way.
This is why I was going with the clustering option. However Clustering obviously gives an ugly voronoi pattern.
I was wondering if there was a way to do this through a turbulent noise so that it is more broken up and it is more procedural.
I did something like this after I applied the noise:
f@fuel=fit01(@fuel,0,10);
f@fuel=rint(@fuel);
However this creates some values to be different still within the area that I want to be all one value.
I will attach an image and scene file to show what I mean.
Appreciate the help!
Clustering_fuel_v2.hip
