Show curve thickness in viewport
14 minutes ago, Skybar said:
On the Geo node; Misc -> Shade Open Curves In Viewport. Also make sure that Display Options -> Geometry -> Shade Open Curves is turned on.
This is what the Hairgen object enables to get the ribbon effect for curves. You can also change "Display As:" to "SubD Surface/Curves" to get the smooth curves as well.
  • Thanks 1
  • 10 months later...
