alexnet Posted August 19, 2018 Share Posted August 19, 2018 The script implements the ability to drag files of geometry, caches, textures, images right into the viewport. This project was open-source, so I spread it for everyone. Can someone come in handy. Thank you for watching! Projects: https://github.com/alexwheezy/python/tree/master/houdini/drag_drop_files 1 1 Quote Link to comment Share on other sites More sharing options...
VTL Posted October 29, 2018 Share Posted October 29, 2018 (edited) Thank's it work Edited October 29, 2018 by VTL Quote Link to comment Share on other sites More sharing options...
kleer001 Posted February 11, 2019 Share Posted February 11, 2019 I was excited to try this, but after installing in my scripts directory and testing with dropping in an abc file I got two error messages: - Load failed for <abc file path> (but it still renames the current scene to that abc path) & - File Drag/Drop Errors ImportError: No module named type_extensions Then I copy/pasted the contents of the type_extensions.py and the nodes_color.py into the externaldragdrop.py and it works. Weird. Quote Link to comment Share on other sites More sharing options...
alexnet Posted February 13, 2019 Author Share Posted February 13, 2019 On 2/11/2019 at 8:38 PM, kleer001 said: - File Drag/Drop Errors ImportError: No module named type_extensions Then I copy/pasted the contents of the type_extensions.py and the nodes_color.py into the externaldragdrop.py and it works. Weird. Expand I think that the $HOUDINI_SCRIPT_PATH variable may simply not look in the folder with these scripts, maybe you didn’t have a typical Houdini installation. On 2/11/2019 at 8:38 PM, kleer001 said: - Load failed for <abc file path> (but it still renames the current scene to that abc path) Expand And what was the exact error there? I'll fix the script. Quote Link to comment Share on other sites More sharing options...
kleer001 Posted February 14, 2019 Share Posted February 14, 2019 The scripts are all right next to each other. No way externaldraganddrop.py could have loaded one and not seen the other two (nodes_color and type_extensions). The exact error is: File Drag/Drop Errors Traceback (most recent call last): File "<stdin>",line 4, in <module> ImportError: No module named type_extensions And, if I comment out that import line I then get the same error for nodes_color Quote Link to comment Share on other sites More sharing options...
graham Posted February 15, 2019 Share Posted February 15, 2019 The nodes_color.py and type_extensions.py should NOT be in the same folder as the externaldragdrop.py. Houdini will use houdini/scripts to find scripts, not Python modules. Since externaldragdrop.py is a script it belongs in there. The other files (as per the instructions) on the should be in houdini/scripts/python, which Houdini will automagically add to sys.path if it exists and then externaldragdrop will be able to import those two modules. Quote Link to comment Share on other sites More sharing options...
berniebernie Posted May 22, 2019 Share Posted May 22, 2019 hello could you give a hand into making this pipeable ? as in keeping it on a server and having it served via houdini.env ? Not sure about the folder structure/ PYTHONPATH etc I'm trying to keep things clean but not super familiar with the whole pipe' Quote Link to comment Share on other sites More sharing options...
fpesantez Posted April 27, 2020 Share Posted April 27, 2020 Hello, does this works on Houdini 18?, I can't make it work on any case, it seems like it's alwyas trying to read a hip file and it errors Quote Link to comment Share on other sites More sharing options...
alexnet Posted May 2, 2020 Author Share Posted May 2, 2020 On 4/27/2020 at 11:42 PM, fpesantez said: Hello, does this works on Houdini 18?, I can't make it work on any case, it seems like it's alwyas trying to read a hip file and it errors Expand Hello! I'm not sure, but the Python API has changed towards the H18.0 approach to using a new approach using Python States because now the goodies are not at all responsive to what you drag from the file fender to the viewport, as if it stopped tracking these changes. Quote Link to comment Share on other sites More sharing options...
vinyvince Posted May 4, 2020 Share Posted May 4, 2020 I think many of us will be thankful to have it working in h18 while hopefully one day Sidefx understand that its a basic but important usefull feature for lookdev and scene assembly. And don t tell me Houdini is only for people , i mean full team with python experts TD. Looks at what the Labs team is developing. There are some great tools, but i believe some are much less important than features like this who should be built in. Or some everyday usefull feature like this addon for example https://l.facebook.com/l.php?u=https%3A%2F%2Fsites.google.com%2Fview%2Fmicrocitygenerator%2Fextras%2Fbgeo-browser%3Ffbclid%3DIwAR0w0dCGh59PJE8rgFn4YT9-6zKFhXozZpqU7zE5-GpQ_r9fElAe4z0P2B0&h=AT1-tZyWUVUuaXZ5TayjDdOFJ9h1ePiFkwtIE9WYscnXgg3kJD4lWp6-xNehSNq7c7M803J3EID_Us_fBXjxRIt_p2CMZvo2dRdUJNVsTx6oGYGGpv1eCZwnwYJfM3kh44lQVv8vNHsa93u9z1c Then How many clicks and so do i have to do to build an arnold shader for example too? Why the Labs quick mat sop isn t directly loading the file input assign to the mat shader attached to the object? Or maybe i missing something? ________________________________________________________________ Vincent Thomas (VFX and Art since 1998) http://fr.linkedin.com/in/vincentthomas Quote Link to comment Share on other sites More sharing options...
Agmadar Posted May 5, 2020 Share Posted May 5, 2020 On 5/4/2020 at 7:20 PM, vinyvince said: I think many of us will be thankful to have it working in h18 while hopefully one day Sidefx understand that its a basic but important usefull feature for lookdev and scene assembly. And don t tell me Houdini is only for people , i mean full team with python experts TD. Looks at what the Labs team is developing. There are some great tools, but i believe some are much less important than features like this who should be built in. Or some everyday usefull feature like this addon for example https://l.facebook.com/l.php?u=https%3A%2F%2Fsites.google.com%2Fview%2Fmicrocitygenerator%2Fextras%2Fbgeo-browser%3Ffbclid%3DIwAR0w0dCGh59PJE8rgFn4YT9-6zKFhXozZpqU7zE5-GpQ_r9fElAe4z0P2B0&h=AT1-tZyWUVUuaXZ5TayjDdOFJ9h1ePiFkwtIE9WYscnXgg3kJD4lWp6-xNehSNq7c7M803J3EID_Us_fBXjxRIt_p2CMZvo2dRdUJNVsTx6oGYGGpv1eCZwnwYJfM3kh44lQVv8vNHsa93u9z1c Then How many clicks and so do i have to do to build an arnold shader for example too? Why the Labs quick mat sop isn t directly loading the file input assign to the mat shader attached to the object? Or maybe i missing something? ________________________________________________________________ Vincent Thomas (VFX and Art since 1998) http://fr.linkedin.com/in/vincentthomas Expand https://www.facebook.com/groups/HoudiniArtists/permalink/2935154009933717/ Quote Link to comment Share on other sites More sharing options...
vinyvince Posted May 5, 2020 Share Posted May 5, 2020 Lewis Orton Hero of the day https://github.com/LewisOrton/Houdini_Scripts Quote Link to comment Share on other sites More sharing options...
