Optimizing white water? (2gb per frame?)
caskal
Hey guys,
I have a flip sim with particle div. at 0.03. Cached the compress and surface. So far all good. Now when I generate the white water, there are frames that go up to 3 gb (and its incremental), any tips for optimizing this?
Some stuff I tried:
- Creating a bound by object group, to delete particles that wont be used
This optimized the size to almost the half
preview-gallery-2018-08-20_14-15-58.png.2c4457c17df476d4b2ec5cc53a201092.pngpreview-lightbox-2018-08-20_14-15-41.png.d371d77eee7809d2fb1a4f42631db8db.png
Size comparison
Another thing I tried is splitting up the "bubbles + foam" and "spray" in different bgeo files
And finally I tried reducing the birth in white water solver as well as lifespan parameters. Is this normal? the size of white water tends to be big and increments over time?
Any tip will be helpful, I have like 300gb for 1/4 of the animation just on white water
Edited by caskal
Update: went from 3gb a frame to 300mb a frame, by deleting non used attributes and using camera culling.
Also tweaked the parameters like withewater birth to 60 instead of 100, and lifespan from 2 instead of 4, not sure if this is already enough, or should I take some of them off? here's a video with mesh+whitewater (bubbles+foam) and the whitewater alone.
Also, for rendering I think the studio is using arnold, what will be the best approach to render whitewater? as volumes? or cloning spheres like in redshift?
Thanks!
