Highlight in viewport ?
4 hours ago, ThomasPara said:
Is that packed objects or instances? If so its the viewport culling the instances.
It's packed objects.
The higher I set the value for Scene Polygon Limit, the less of the `shadow` on the mesh I see but the slower the object is to navigate in the viewport ? Although the `shadow` even when the Scene Polygon Limit is set to an extremely high value, is still present on the mesh ?
The shadow is the individual bounding boxes of the instances being culled. It looks like a solid blob because they're all overlapping. This is a feature that prevents instancing from generating a massive number of polygons to draw, which can slow your redraws down (and if you're on Windows, cause the driver to reset). You can tweak the Scene Polygon Limit to balance redraw speed with the # of instances actually drawn.
  • Thanks 1
