Create rotation control for polywire
evanrudefx
I am trying to set up controls for rotating the geometry created by polywire. I saw this post, but the scene doesn't work for me.
https://forums.odforce.net/topic/25804-how-to-turnrotate-an-polywire/
I figured out how to gain some control by creating a local variable upvector and binding the joint up vector in poly wire to it. The part that confuses me is how to just create a slider that would allow me to continuously rotate, like in the example in my scene.
Thanks in advance
rotate_polywire.hiplc
  • 1 year later...
On 11-9-2018 at 3:37 PM, vicvvsh said:
Hi Evan,
I fix the scene from the topic that you pointed at and I added checkbox for only rotation or spiral. See red attribute VOP.
orient_polywire_sweep.hipnc
Just what I needed. I do have trouble understanding what you done in the AttribSop. As far as I do understand you need to alter the upvector on everypoint. Could you elaborate on how it works? if you have the time.
I don't remember what exactly i did, this was more then one year ago. I copied "rotate_upvectors" attribute vop, cleaned it up  and added a checkbox, that's it. How it works? If i understood your question correctly it just multiplying rotation angle value to first component of @uv, which has value from 0 to 1. Then we multiply v@upvector by matrix which we are getting within rotate vop.
