kubabuk Posted May 3, 2006 Share Posted May 3, 2006 Hi I need to save zdepth information as a rgb file, how can I extract Z channel from the houdini *.pic format. Every attempt (saving straight from mplay or saving as Pz.jpg in the deeprasters tab didn't succeed... (I always get b&w image) Futhermore sometimes when I render with pic format I get correct grayscale image and other time just black and white (see attachment) What am I doing wrong?!? Pleasy heeelp! Thanks, Kuba Quote Link to comment Share on other sites More sharing options...
malexander Posted May 3, 2006 Share Posted May 3, 2006 Z map images in Houdini aren't normalized to the 0-1 - they are effectively HDR images. So saving it to a format that doesn't support HDR will lose most of your information, and it'll look B/W. You would be better off trying to save it to a format that supports HDR, like TIFF or EXR. In the MPlay Save As... dialog, change the Color field to 'Pz' (and set the Alpha field to None) and then save. You can also save it into a pic by setting the scope to 'Pz'. If you REALLY want to save it to JPG, though, display the depth plane, click "Adapt to Full Pixel Range' (hotkey Shift+R) and then select Save->Preview. This will normalize the depth to 0-1 for you, making your resulting JPG look more like a Z map. Quote Link to comment Share on other sites More sharing options...
kubabuk Posted May 5, 2006 Author Share Posted May 5, 2006 Thanks for response. The trick with saving as a TIFF works but after I load it again I have to "Adapt to Full Pixel Range" to see the results. But I can't still load this image to photoshop. I also tried the solution saving the preview as jpeg. But it doesn't work for me I still get B&W image. Do you think my scene is so huge that it doesn't fit the zdepth range...? Cheers Kuba Quote Link to comment Share on other sites More sharing options...
crunch Posted May 5, 2006 Share Posted May 5, 2006 Thanks for response. The trick with saving as a TIFF works but after I load it again I have to "Adapt to Full Pixel Range" to see the results. But I can't still load this image to photoshop. I also tried the solution saving the preview as jpeg. But it doesn't work for me I still get B&W image. Do you think my scene is so huge that it doesn't fit the zdepth range...? Cheers Kuba 27257[/snapback] Hi... The pixels in the z-depth image are stored as floating point numbers. Each pixel represents the distance from the camera of the surface which was rendered. So, if you have a grid that's 5 units from the camera, the pixel will have a value of 5 (very bright). There's a command line tool called "izg" which will convert a depth image to a gray scale image. You might want to try processing the .tiff file using this application. izg -a zdepth.tiff zdepth.jpg You can also do a similar effect in COPs by adjusting the contrast of the image so that the brightest pixel goes to 1 (in the case above, you'd want to set the contrast to the range 0-0.2). However, this is probably a little harder to control. 2 Quote Link to comment Share on other sites More sharing options...
peliosis Posted May 5, 2006 Share Posted May 5, 2006 Hmm, why not create a vop shop for this, and have a two slider (near/far) control? This is quite easy to do and very easy to control yet very flexible. An example is in the pintable tutorial. Quote Link to comment Share on other sites More sharing options...
Mario Marengo Posted May 5, 2006 Share Posted May 5, 2006 Hmm, why not create a vop shop for this, and have a two slider (near/far) control? This is quite easy to do and very easy to control yet very flexible.An example is in the pintable tutorial. 27263[/snapback] Unless you're always working with static scenes, I don't think SHOPs are the way to go on this. Best leave range mapping to post, IMHO, because there you have the option of either a constant domain (near/far parameters), or a dynamic one (min/max per frame or per sequence). Quote Link to comment Share on other sites More sharing options...
kubabuk Posted May 5, 2006 Author Share Posted May 5, 2006 Thanks for help, it works now. I've wrritten down everything step by step in case anyone comes up the same problem. I render and save file as a houdini *.pic format with the Pz variable in Deep rasters tab Open rendered file (with mplay) change from color to Pz, "save current frame" as a tif file, change the "color" to PZ and "alpha" to none. open the tif file once again with mplay and SHIFT+R to Adapt to full pixel range, and save as a tif. open IZG command line tool and convert the file to jpg: izg -a file.tif file.jpg Quite tedious work but at least I can load Zdepth files in Photoshop... Kuba Quote Link to comment Share on other sites More sharing options...
Mario Marengo Posted May 5, 2006 Share Posted May 5, 2006 Thanks for help, it works now. I've wrritten down everything step by step in case anyone comes up the same problem. Another method you may want to try: 1. Load the Pz image (or whatever floating point image/channels you want to normalize) into the compositor (File COP). 2. [optional] If this is a deep raster .pic file, you may want to add a ChannelCopy COP to put Pz (or whatever) into the R,G,B (A) channels. 3. Follow with an Equalize COP to do the normalization. 4. Append a Convert COP to convert back to 8-bit, and save the result in any format you like. Basically: you can use the Equalize COP to normalize your floating point channels. Quote Link to comment Share on other sites More sharing options...
sibarrick Posted May 6, 2006 Share Posted May 6, 2006 open IZG command line tool and convert the file to jpg: izg -a file.tif file.jpg 27280[/snapback] Why would you save to a lossy format like jpg? I would stick with tif or tga or something non lossy. Quote Link to comment Share on other sites More sharing options...
symek Posted May 6, 2006 Share Posted May 6, 2006 Thanks for help, it works now. I've wrritten down everything step by step in case anyone comes up the same problem. I render and save file as a houdini *.pic format with the Pz variable in Deep rasters tab Open rendered file (with mplay) change from color to Pz, "save current frame" as a tif file, change the "color" to PZ and "alpha" to none. open the tif file once again with mplay and SHIFT+R to Adapt to full pixel range, and save as a tif. open IZG command line tool and convert the file to jpg: izg -a file.tif file.jpg Quite tedious work but at least I can load Zdepth files in Photoshop... Kuba 27280[/snapback] Gosh! so many steps to do so simple task? Just render your file with pz plate (or plug in pz to cd in vop - you have then inaccurate but smooth edges deph map ) equlize it in cops to see you whole range of Pz, then save as tiff with forced 8bit depth. Quote Link to comment Share on other sites More sharing options...
symek Posted May 6, 2006 Share Posted May 6, 2006 Gosh! so many steps to do so simple task?Just render your file with pz plate (or plug in pz to cd in vop - you have then inaccurate but smooth edges deph map ) equlize it in cops to see you whole range of Pz, then save as tiff with forced 8bit depth. 27290[/snapback] sorry, I've just read Mario post... Quote Link to comment Share on other sites More sharing options...
kubabuk Posted May 8, 2006 Author Share Posted May 8, 2006 Big thanks once again, I attach this time COPs network, which works very fine as well Cheers Kuba 1 Quote Link to comment Share on other sites More sharing options...
symek Posted May 8, 2006 Share Posted May 8, 2006 Big thanks once again, I attach this time COPs network, which works very fine as well Cheers Kuba 27352[/snapback] (1) what is the first convertCOP for? Pz IS in floating point format so it doesn't have to be converted. (2) you can even simplify this network by converting to 8bit in file format options, which have bit depth converions for most of file formats (so second convertCOP is optional also). (3) if your plan is to use Pz outside Houdini and Halo, it's better as I suppose to store depth map in other file then your render, so you can use it just out of mantra in any application with support for 32bit per channel images. This extra step in Halo will be then unnecessary. After that you can still use it of course in Halo, just using CopyChannel COP. cheeers, SY. Quote Link to comment Share on other sites More sharing options...
EGGer Posted May 8, 2006 Share Posted May 8, 2006 here is another method: 1) inside shop, create a vex z-depth fog. 2) In object level, create Atmosphere node . choice shading tab, and connect shop volume to vex z-depth fog. then you can render a z depth file hehe... 1 Quote Link to comment Share on other sites More sharing options...
kubabuk Posted May 8, 2006 Author Share Posted May 8, 2006 (3) if your plan is to use Pz outside Houdini and Halo, it's better as I suppose to store depth map in other file then your render, so you can use it just out of mantra in any application with support for 32bit per channel images. This extra step in Halo will be then unnecessary. After that you can still use it of course in Halo, just using CopyChannel COP.cheeers, SY. 27355[/snapback] Hi SYmek, (3) For some reason rendering zdepth as a separate file didn't work for me - every time I got B&W image as the pixel range was shifted, but at the same time I couldn't correct that in mplay. (1) Previouslu I tried not to use the convertCOP and I got incorrect results, with ConvertCop everything works fine. Probably it depands what sort of channel depth I used for rendering color and alpha (I'm not sure but accidently I might have chosen 8bit in the render options...) Kuba Quote Link to comment Share on other sites More sharing options...
afx Posted March 14, 2009 Share Posted March 14, 2009 (edited) EGGer, works great, I figured there had to be an easier way to pull this pass, I also used a Constant Material and mapped all my Geometry to this SHOP. Then took your suggestion and placed an Atmosphere Node and set its material to the VEX Z-depth fog (I also changed the Fog color to Black). My Geometry had the default shader assigned to it and its Specular and Lambert shading were taken into effect by mantra. Using the Constant Material, this eliminated the Specular highlights and made it workable in nuke and fusion Z-depth nodes. Awesome post!!! I was looking for a logical solution. Edited March 14, 2009 by Angelo Quote Link to comment Share on other sites More sharing options...
afx Posted March 14, 2009 Share Posted March 14, 2009 (edited) Any one know of a VEX shader solution?? Edited March 14, 2009 by Angelo Quote Link to comment Share on other sites More sharing options...
symek Posted March 14, 2009 Share Posted March 14, 2009 Any one know of a VEX shader solution?? solution for what? Quote Link to comment Share on other sites More sharing options...
FJsam Posted April 20, 2019 Share Posted April 20, 2019 On 5/8/2006 at 2:55 PM, kubabuk said: Big thanks once again, I attach this time COPs network, which works very fine as well Cheers Kuba Thank you for helping after 13 years 2 Quote Link to comment Share on other sites More sharing options...
