Python in Houdini : Right or Wrong ?
there's absolutely nothing wrong with it, unless you're using a lot of Python to manipulate geometry where you could otherwise do it in VEX. and even then, if you're using SOP verbs there's a lot you can get away with performance-wise.
the only thing you need to be careful about is python library dependencies. if you're using third-party libs that aren't shipped with houdini, and you need to distribute your tool, things can get a little hairy.
