Print an array element for debugging
Alexandre
Hi everyone !
I'm learning VEX (from CGwiki and Entagma) and I don't understand why the result of the following code is 0 whereas it should be 3... what did I misunderstand ?
int myarray[] = {2, 3, 4, 5};
int foo = myarray[1];
printf("%i \n",i@foo);
Thanks !
Alexandre
Another question which is a step further... but still low level
I want to access to a specific float attribute called d (related to a distance), I have tried attrib, point, pointattrib... I don't understand how to access to the nth value of d. Moreover I don't understand what mean the integer "&success" in the help function
In the example in attachment I would expect to get 1.49176 instead of 30 times "0.0000"
thanks !
Alexandre
You should give up using prints with vex, just use the spreadsheet as your print out. There is no need to fetch the point value of @d from the point that you are running over. Just use @d. Vex is a sand box. when you enter the wrangle, the information about points is made available to the wrangle, kind of like a copy. You can operate upon those entries, then when you exit the wrangle internal housekeeping remaps everything to make the output work correctly. This prevents you from performing certain operations typical in a top-down programming language. It also prevents you from messing up indicies.
Try using two wrangle, one to add new points and the other to review or revise those points.
You are trying to print @d for point #1.
Try...
if(@ptnum==1) print("%02d\n",@d);
You should not ignore the success flag either. Pass a valid variable, not 0.
Also I don't think primuv returns a point that you can just pass to addpoint. It returns the value at the UV coordinate. This would cause all the other operations on that point to be suspect. Your getting 30 zeros because the pointattrib is failing, you are not examining success and a zero is returned just as the documentation states.
