Measure length ?
In addition to what Jesper said, even if you don't model to scale, but know the relative conversion ratio of your model the value should be correct. For example, if you are taking terrain data and scaling a mountain to the correct size, you can not do it at real world scale due to precision issue of 32/64 bit precision, however, you can scale your object by a percent and be good enough for CG.
